Pop up Livorsi Led Bow light questions >
Old 01-31-2012 | 09:20 PM
Question Pop up Livorsi Led Bow light questions
Has anyone installed a Livorsi pop up led bow light..? The instructions online say that you have to drill a 3" hole in your boat...which isnt so bad but then I see they offer a cup to go under the light to catch the water but where would I route the water to so it doesnt ruin anything..?
FIVEPTOHH is offline
Old 01-31-2012 | 09:41 PM
I drilled a small through hull with a screen cover to let water drain. Tube attached to that runs up to the cup.
GTOFFSHORE is offline
Old 02-01-2012 | 07:48 AM
they make a little thru hull fitting that you can route right out of the side of the bow. I have one on each side, one for the light and one for my pop up cleat.
Philm is offline
Old 02-01-2012 | 11:14 AM
Yes that's what we have thanks for a better explanation
Old 02-02-2012 | 09:16 PM
So does anyone think they are worth the effort..?
Old 02-03-2012 | 07:53 AM
Yes, they are worth the effort. Unless you like water in your bow.
Philm is offline
Old 02-03-2012 | 10:26 AM
On the fountains in drains all the way back to the bilge as long as all the passage ways are clear...
jmoore1225 is offline
Old 02-03-2012 | 10:38 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
Doesn't yours have the small plastic thru hull drain fitting for the compartment behind the front mirror already? (Looks like a gas tank vent) Tie into that, or install one.
US1 Fountain is offline
Old 02-03-2012 | 08:05 PM
I donno if it does...how would I know..? Should I remove the mirror and look behind it..?
Old 02-04-2012 | 01:22 PM
Ginger or Mary Ann?
If you do, there will be the small clam shell looking vent up below the bow eye, where you hook your winch strap.
