Deck Removal?
Old 02-06-2012 | 02:16 PM
Default Deck Removal?
Picked up a 72 Glastron 177 "Swinger" (no comments please :-) ) and it is a project. The floor is spongy so I know it needs replacing, maybe the stringers too. Pulled the carpet and boy, was the factory cheap on the resin covering the floor! There are holes in the matting where the resin wasn't worn - it was just never flowed!
Anyway, to remove the floor, do I grind, sand or cut the bond along the side hull? I don't want to cut too deep and compromise the hull, so I am thinking a good 60 grit wheel to remove the resin and matting then pull the boards..
Am I on the right track?
LHC30Victory is offline
Old 02-06-2012 | 05:50 PM
Default fixx
all honesty,,if its that rottin i would use a air chisel with a muffler cutting bit,,goes theough it like butter..after cutting the edges you can remove the whole section,this way will keep the grinding dust down and once everything is removed you can grind the edges to smooth everything out..
FIXX is offline
Old 02-06-2012 | 06:48 PM
That chisel sounds like the plan...I hate glass dust and I end up with a pattern...Thanks
