fel pro mls or cometic...need part #'s please >
Old 02-11-2012 | 04:30 PM
Default fel pro mls or cometic...need part #'s please
Hey Guys,
Need some help here. I've looked through the forums and am having no luck here. I need to buy head gaskets for my build and can't find the info I need.
I have a gen 6 502 that's .60 over (4.530 bore) with Merlin grumpy Jenkins iron heads. This motor has a B&M 250 blower on it so I want to run either a cometic head gasket or a fel pro mls head gasket....which one do you recommend???? And if you could give me a part # that would be awesome!
mustangmark is offline
Old 02-12-2012 | 06:03 PM
GPM
Fel pro 1075
GPM is offline
Old 02-12-2012 | 07:05 PM
Originally Posted by GPM
Fel pro 1075
+1,felpro 1075,thr block&heads need a smooth surface to use this style gasget,the felpro marine gasget is also a good gasget if you dont want to deck the block&resurface the heads.
mike tkach is offline
