Cam Specs on a standard 502 GM Marine engine? >
Old 02-13-2012 | 11:20 AM
jmz
Default Cam Specs on a standard 502 GM Marine engine?
I am in the process of a repower on a Donzi 22. I went with the 502 crate (marine) from 1800runsnew.
I called and asked them what the cam specs are and their response was that G.M. keeps those specs close to their chest and that they did not know the specs. ...sounds like B.S. to me but that is as far as I got.
Does anyone know what the cam specs should be? ...standard 502. I am trying to order a distributor from DUI and they ask for the cam specs so they can set the advance up properly.
Thanks,
Jay
jmz is offline
Old 02-13-2012 | 11:45 AM
ENGINE MODEL
454 MAGNUM
502 MAGNUM
8.2L
Lobe Lift + .020 (0.051)
Exhaust
.342 (8.687)
Intake
.342 (8.687)
Duration at .050 In. (1.27 mm)
Cam Lift
Exhaust
227°
Intake
211°
Journal Diameter
1.94282-1.9492 (49.485-49.509)
Journal Out Of Round
.001 (0.025) Maximum
Camshaft Runout
.002 (0.051) Maximum
Timing Chain Deflection
3.375 (9.5) from taut position [total .75 (19)]
Baja226sport is offline
Old 02-13-2012 | 11:49 AM
Found that @ Perfprotech.com
Do a little looking on yahoo or google. It is not hard info to find. No secret. It would be mercruiser info not gm you would be looking for.
Old 02-13-2012 | 12:19 PM
GEN 6 Billet Roller Cam
Mercruiser 454 502 Mag Roller
Merc# 431-850478 / GM#12551622
.004 300*/ 300*
.006 288*/288*
.050” 225*/225*
.200” 125*/125*
Lift .483”/. 483”
ICL 109*
LSA 115.5*
I also purchased two brand new engines from 1800runsnew
Took them apart to put in RMBUILDER cams, and did some headwork.
Best of everything, no problems whats so ever.
1BIGJIM is offline
Old 02-13-2012 | 12:24 PM
.004 300*/ 300*
.006 288*/288*
.050” 225*/225*
.200” 125*/125*
Lift .483”/. 483”
ICL 109*
LSA 115.5*
What kind of gains did you see with the Bob cam? Did you do anything else? Different springs, lifters, valves, rocker ratio ect.?
A.O. Razor is offline
Old 02-13-2012 | 08:04 PM
Yes, I had to change the springs to match the cams.
As always, great idle, they pull to 5,000rpms no problem.
The other reason I wanted new cams, was to get a fuel pump lobe.
If I had to do it all over again, I would have saved the money for $4.00 a gallon gas.
1BIGJIM is offline
Old 02-14-2012 | 05:46 AM
4$? C'mon. You should try boating around here. 9$ a gal.
Old 02-14-2012 | 06:29 AM
I would have to get rid of the first mate.
1BIGJIM is offline
Old 02-14-2012 | 07:41 AM
.004 300*/ 300*
.006 288*/288*
.050” 225*/225*
.200” 125*/125*
Lift .483”/. 483”
ICL 109*
LSA 115.5*
This is the right spec numbers for the new GM base 502 new engine only
Rockfish71 is offline
Old 02-14-2012 | 11:27 AM
jmz
Thanks All.
My plan is to run it for a season and then consider going for a cam change too.
jmz is offline
