Safe Guards to avoid reversion/ingestion >
Old 02-22-2012 | 07:43 PM
Default Safe Guards to avoid reversion/ingestion
Lets say you have a cam selection that is slightly prone to reversion issues. Without tearing the motors down and changing the cams what are some things that you can do to make sure you are issue free? Setup has stock Gil exhaust on 502mpi's.
My thoughts so far:
Fresh flappers and butterfly flappers
Long turndowns/donkey dicks that would inhibit splashback
Longer risers so water is dumped further back
Mufflers
Appreciate any input.
baywatch is offline
Old 02-22-2012 | 07:56 PM
Dry pipes
KWright is offline
Old 02-22-2012 | 10:29 PM
Friend built his 34' boat a few years ago with a single engine in mind.We've opted for the ZZ572 engine with Stellings dry exhaust.It worked great until the inner jacket at one of the exh flange cracked and doused the exh valve and dropping it.We had to scrap the dry exhaust idea and had Eddie Marine fab a s/s wet one to our spec, mounted on the EMI aluminum unit.We had to get the risers taller than the stock units readily available to stop reversion. 500 hrs on the engine and boat ,running top as a commuter on weekends.
Original setup
Present setup
spectras only is offline
Old 02-22-2012 | 11:10 PM
Wow, That is cool looking boat.
As far as the dry exhaust is concerned It would still need to be muffled since boat is primarily used at LOTO and have to keep it to the 90db to keep the water cops happy. Was just looking for things that can be done to help lessen chances of an issue. Also got to thinking that the soleinoid actuated switchable exhaust function should probably be done away with.
baywatch is offline
Old 02-22-2012 | 11:45 PM
If your running diveters like the Crosa, take out and put longer risers and problem solved, add mufflers if then too loud.
osur866 is offline
Old 02-23-2012 | 01:25 AM
My thoughts so far:
Mufflers
Josh, you worry too much
Really though, I don't think the slightly upgraded cams PBB used will cause any reversion issues. The Gils are fine for much more cam than what you have.
For the other type of reversion from wave splash back, you could put on some Drew Marine Shotgun muffler tips. They are 90% closed at idle and low rpm and open up with exhaust pressure so there is no restriction or loss of power.
Griff is offline
Old 02-23-2012 | 06:57 AM
Scott, I am a tad on the paranoid side. I"ll give you a call this afternoon.
baywatch is offline
Old 02-23-2012 | 08:57 AM
blue thunder's Avatar
My thoughts so far:
Mufflers
One big thing to do is keep your idle as high as possible and do it as little as possible.
blue thunder is offline
Old 02-23-2012 | 10:03 AM
swan2's Avatar
Talking
Man that is the coolest boat that thing is awsome what kind of speeds do you get out of her??? But great looking boat for sure...
swan2 is offline
Old 02-23-2012 | 12:12 PM
Are you talking about my friend's boat? With the Steliings dry exhausts, we GPS'd the boat at 65 mph.
Before we added more crap like extra heaters, radio etc.....the boat weighed in a little over 6000lbs.
My friend used foamcore to make the boat light enough for a single.he doesn't care much about top speeds because it's a commuter he uses between Vancouver and Vancouver Island.
Here are some more pictures if you guys interested.
His exhaust is different now from this one
We have four recliner seats out of an Astro van.
Before paint on white gelcoat
Finally ,a slow test run footage
http://www.youtube.com/watch?v=BkUKYapf-dI
