For All The Guys Wanting to Build Their Small Block..
ive noticed a lot of posts about guys wanting to add some ponies to their small blocks, here is a link to my build from last year, it may help answer some questions you may have. after i got it together the thing runs great, im gonna work on fine tuning it this year, hope this helps.
http://www.offshoreonly.com/forums/d...under-way.html
No dyno, wish I could have but don't have access to one and really not to worried about it, I've seen 64 mPh in the boat and I haven't dialed the carb in yet so I'd say I can get 65-66 pretty easily. It only ran 52-53 before so I was more than pleased with results
2 Bolt Main Block
Edelbrock 1409 Marine Carb 600CfM
Scat Rods 5.7 Pressed Pin forged
TRW L2256F + .030 Pistons Forged
Melling's M55Hv Oil Pump
Vortec 12558060 - SD8060A Heads
Comp Roller Tip cc1417-16 Rocker Arms
Comp Cams XM270HR Roller Cam
Hydraulic Roller Lifters
Cloyes True Roller timing set
Edelbrock 7516 RPM Air Gap
Crane Ignition HI-6M
Clevite Bearings
ARP Fasteners
GLM Aluminum Semi Tuned Exhaust Manifolds
Through Hull exhaust with Corsa exhaust tips
K&N Flame Arrestor
Powder Coated Stock Valve covers
I believe i am right around 350 HP at Flywheel. The Mariah 212Z is a narrow beam lightweight Bow (similar to a Stingray) and has a lot to do with the 10 extra mph. If the same motor was in a Sea Ray, Crownline, Cobalt of same length you would not be near 63.8mph (heavy wide beam boats) more like 58mph Max.
Congrats nice build
I guess I could post my specs as well, I don't remember the detas on the bearings and timing chain and what not because my builder ordered all of that but I will post what I know
350 CID from a 1997 truck
903 vortec heads
Performer rpm intake
650 demon carb ( currently jetted to rich but fixin to fix that)
Lt4 hot cam kit with 1.6 roller rockers
9.8:1 flat top pistons ( forged )
Stock gm crank and rods
Block decked ( I think it's .013 in the hole )
Crank balanced
Stock merc exhaust for now
Thunder bolt Iv ignition
903 vortec heads
Crank balanced
Another good tip is that I have always ran Amsoil 15w40 Diesel and Marine motor oil which I believe is a major part of an engines life.
