Formula 292 with Gils >
Old 02-24-2012 | 08:57 AM
Default Formula 292 with Gils
I'm installing Gils on my 292 SR1. They are wider than the stock manifolds and I'm going to have to move the ram that raises the hatch because right now its in the middle of the manifolds. For those of you with gils or other manifolds where is your ram? In front or in back of the engines?
endeavour32 is offline
Old 02-24-2012 | 11:05 PM
The hatch lift is in front of the engines on my 32 Fountain w/ Gil manifolds.
JD33 is offline
Old 02-26-2012 | 01:37 PM
My ram is positioned just behind the manifolds
amazing1 is offline
Old 02-26-2012 | 02:39 PM
Thanks guys! I think I'm going to try it behind. That way I'll be able to get to the plugs better as well as have more lift on the hatch.
Old 02-26-2012 | 05:13 PM
you may need to add spring loaded shocks on the side if you go behind. ram will have much less leverage-much more weight. and most manufacturers don't install anything that is a lot stronger than it has to be.
dereknkathy is offline
Old 02-26-2012 | 05:54 PM
Formula put 420's in the 311 and 357's which would have had gils on them and also have the same beam as the 292 which is 8 feet. So there is a way Formula did this from the factory as there isn't enough room to mount the ram with between the manifolds if gils were used. If there is one thing I can say about Formula, it's that they don't skimp when building boats. Their boats are heavy for a reason.
