Engine Wire Harness Connector? >
Old 02-28-2012 | 11:34 PM
Default Engine Wire Harness Connector?
Anybody know where I can find a wire harness connector that would plug into the main connector on the Merc. engines?
I need the end that would be wired to the boat, I'd like to make a connector to use on a engine dyno.
JD33 is offline
Old 02-28-2012 | 11:40 PM
blown formula's Avatar
How many pins in the connector you want?
blown formula is offline
Old 02-28-2012 | 11:47 PM
CP Performance sells them. They have them with the plug and about 1' of wire if you were just changing the plug in the boat. They also have longer ones , but they will probably be to long. Your best bet may be the short one and you can just add to it as needed.
Eddie
Young Performance is offline
Old 02-29-2012 | 06:48 AM
got one from a 1996 5.7 carb lx $10 tyd
mach1magnum is offline
