Misc Boat Parts
Old 03-05-2012 | 08:26 PM
Default Misc Boat Parts
Two home made Water Bypasses for BBC. These are thin wall stainless tubing, 1" OD. $60 for the pair Shipped.
Two Stellings Water Goose Necks for Bravo Extension Boxes. Installed but not used. $80 for the pair Shipped.
Two Pairs of Factory Merc Stainless Risers for stock manifolds. One set has AEC cast into the side, the other set has 816900-C. $135 per pair Shipped.
Used Imco Hydraulic Steering Parts. $372 from IMCO, $200 Shipped.
Includes:
1 Ea. TB-21 TRANSOM BRACKET KIT RECTANGLE RH BULKHEAD TUBES 1 $205.19 –Missing bolts not sure if it is RH or LH part (will need to look).
2 Ea. MP-14 CLEVIS ASSEMBLY .750" ID BUSHING X .500" DIA BOLT POLISHED 316/304 SS $71.06 – Missing bolts
2 Ea. FA-16 ADAPTER -6 SWIVEL T SS 1 $27.50 EA.
Gale Banks Intercooler Heat Exchangers for Stage III Intercoolers. There are 4 Harrison 84J 8533329 cores (2 engine sets) and one has a leak. I received these with Turbo set ups I purchased in 1992 and they have been in my basement since then. When I purchased them I was told one leaked and the others were good. I have not tested them so they are for sale as is with no warranty. $85 Shipped.
Inspector is offline
Old 03-05-2012 | 08:29 PM
johnnyboatman's Avatar
what are the imco parts
johnnyboatman is offline
Old 03-05-2012 | 08:57 PM
Old 03-05-2012 | 09:48 PM
Old 03-07-2012 | 09:12 PM
Default More Stuff
2 502 MPI camshafts from 1997 Gen VI engines. 250 hours use. $65 each Shipped.
New Bravo One Input Shaft. Just the part from the U joint into the Drive. $80 Shipped.
Old 03-07-2012 | 09:30 PM
Part #22 or #26 in this diagram????
http://www.mercruiserparts.com/Show_...TER+COMPONENTS
Griff is offline
Old 03-08-2012 | 08:22 PM
Default More and Pictures
The yoke has part number 12784T on the box. Picture below.
Also have complete Bravo One U Joint Assembly. Used, $225 shipped.
Old 03-10-2012 | 02:34 PM
Bump.
Old 03-15-2012 | 05:53 PM
Still Available...
Old 04-11-2012 | 11:43 AM
Bump.
