Drives Aligned/Lubed?
Old 03-06-2012 | 02:53 PM
Default Drives Aligned/Lubed?
How often do you guys recommend greasing U joints and greasing aligning the drive coupler? I had my coupler changed a few years ago and had everything lubed and aligned then, how often should I have it done again? Is it something that can be done easily?
Thanks guys!
Michael
n20michael is offline
Old 03-06-2012 | 05:29 PM
I pull my drive before every season and grease the u-joints and check the alignment, bellows, etc. It's not hard and takes about one hour. Have someone to help you lift the drive off and on. The factory alignment tool is expensive but I got one from this seller on Ebay and it works great! He even includes directions on how to do the alignment with the tool.
http://stores.ebay.com/whoyaproducts
Sunrocket24 is offline
Old 03-06-2012 | 10:08 PM
Yup. A yearly check when I service my drives. Hasn't moved, but it gives me peace of mind.
Kenthegreenkeeper is offline
Old 03-06-2012 | 10:10 PM
How much would you guys expect to pay for a shop to do this along with bellows while they are changing engine/drive oil?
Plowtownmissile is offline
Old 03-07-2012 | 04:08 PM
Typically, if they have the drives off to lubes the u-joints, they'll check it while it's there.
If it needs aligned, they'll charge you more for that.
Old 03-14-2012 | 10:08 PM
The coupler does not get aligned, the engine does. It is standard procedure to check the alignment before re-installing the drive. It is just a metal shaft of the proper dimensions. If it slides in easily the alignment is OK. Takes about 15 seconds.
gonzocl is offline
Old 03-15-2012 | 01:18 AM
You should grease your coupler at least every year or 50hrs. You can grease the coupler zert from inside the bilge.
Griff is offline
Old 03-17-2012 | 06:59 PM
Hey Griff
I have a 24 Baja Outlaw, any idea where the zert would be to grease the coupler?
Thanks!
Michael
Old 03-17-2012 | 07:13 PM
I pull my drives before every the start of the season and grease the u-joints and check the bellows & alignment
Pot of Gold is offline
Old 03-17-2012 | 08:05 PM
Default fixx
Originally Posted by n20michael
Hey Griff
Thanks!
Michael
you need to hang over the engine,,look at the rear of the engine and you will see where the drive shafe goes into the coupler,their will either be 2 zurts sticking out the back of the coupler or one zurt if it has the steel hp coupler..may have to rotate the engine to get the grease gun on the zurt.
FIXX is offline
