Swivel pin clearance/tolerance question??? >
Old 03-06-2012 | 06:45 PM
blown formula's Avatar
Exclamation Swivel pin clearance/tolerance question???
Does anyone know the bushing to swivel pin clearance or tolerance? Can anyone measure a good or new swivel pin so I will know if I need to replace one or both of my s. pins......
both have different dimensions by a small amount, but how much is too much??? New pins are expensive, so I do not want to replace them if not needed.
Thanks in advance!!
Last edited by blown formula; 03-06-2012 at 06:46 PM. Reason: to subscribe to post
blown formula is offline
Old 03-06-2012 | 08:01 PM
How about a hint. What set up is it.
picklenjim is offline
Old 03-06-2012 | 09:17 PM
Bravo 1 swivel pin (gimble ring swivel pin) ... Sorry, but that is the only swivel pin on a boat I was aware of..... Sonic 30SS. My bad!
Old 03-07-2012 | 06:54 PM
Well, I don't know if anyone else is interested....
but the stock swivel pin measures-
bushing surface 1.122"
square part for the gimble is 1.375"
Old 03-10-2012 | 07:06 AM
Have you tried re-torquing them?? Most people never re-torque them as part of a maintance program. They get loose, then wear prematurely. I have been able to get them to tighten up a bit with a re-torque to spec.
MILD THUNDER is offline
