Motor mounts - baja >
Motor mounts - baja
Motor mounts - baja
Old 03-07-2012 | 10:40 AM
Default Motor mounts - baja
I purchased a baja 24 outlaw without power. The front motor mounts that came with the boat are the type that attach to the top of the stringer. These mounts have no adjustment. Instead where the large stud would normally be just looks like a solid bushing that is bolted from the engine motor mount down. Has anyone heard of this? How is alignment adjusted with these? I wouldn't mind going to the stock setup which I think is normal Merc adjustable mounts with some sort of guard that covers the stringer bolts and is thru bolted by one bolt thru the stringer. Has anyone heard of this kind? If so where can I get the cover piece? I have a hole in the stringer for this cover piece.
FBRONCO is offline
Old 03-07-2012 | 07:25 PM
ttt
FBRONCO is offline
Old 03-07-2012 | 07:32 PM
Pictures are worth a million posts.
1BIGJIM is offline
Old 03-07-2012 | 07:42 PM
Ebay Ed's Avatar
are these what you are looking for i also have the other half that attaches to the block but they are still on my engine in Florida but i should be able to get them shipped if needed
www.bajaboatowners.com
Ebay Ed is offline
Old 03-08-2012 | 06:57 AM
I don't have a picture of what I'm looking for because the boat doesn't have them on it now. The following thread has the type that came with it stock I believe. I'm just looking for the stringer side.
http://www.offshoreonly.com/forums/d...lts-loose.html
How do I post pictures? On the lower left of my screen under posting rules, it says You may Not post attachments.
FBRONCO is offline
Old 03-08-2012 | 08:00 AM
You have to be a paying member to post pics. If you like, you can email them to me and I'll post them up?
A.O. Razor is offline
Old 03-08-2012 | 08:21 AM
c_deezy's Avatar
Is this what you are talking about?
c_deezy is offline
Old 03-08-2012 | 11:29 AM
Yes. Those are it! Looks like stock merc mounts with that cover piece that is through bolted. I'm sure I could get the stock merc mounts somewhere, but where do I get the cover piece? I'll be pulling the transom assembly and k-planes this weekend so I can clean/sand/smooth and paint bilge. I will upgrade my membership so I can attach photos of the mounts that came with the boat. They are not adjustable, and was wondering if anyone has seen this type before. Maybe they are better than stock Merc, but I don't think I like the non-adjustability factor.
FBRONCO is offline
Old 03-08-2012 | 11:58 AM
c_deezy's Avatar
I don't know if I still have the 'covers' or not, I'll take a look in the next couple of days and see. Pretty much all they do is keep the lag bolts from backing out.
From what I recall all they were, was a piece of angle aluminum slotted to go around the mount.
c_deezy is offline
Old 03-08-2012 | 06:55 PM
Here are pictures of my solid non-adjustable motor mounts. Ever see these?
Attached Thumbnails Motor mounts - baja-motormounts_web.jpg   Motor mounts - baja-motormounts2_web.jpg
FBRONCO is offline
