roller cam
Old 03-09-2012 | 12:18 AM
Default roller cam
I have to change cam on my sbc 350 290 hp .Is it worth spending extra money for roller and what are the benefits.
Anyone have any ideas about this. IHAVE A 21' RUNABOUT with a 280 volvo stern drive.
gsickavish is offline
Old 03-09-2012 | 09:40 PM
Default fixx
no! with the 280 drive you will see vary little gains in mph..but a hotter flat tappet cam would be better..i suggest a comp cams xtreme marine cam,i would not go any bigger then the first cam on the list or you will be changing your exhaust..
http://www.flatlanderracing.com/compcams-sbc01f.html
FIXX is offline
Old 03-11-2012 | 08:54 PM
If you only want 290HP out of a 350 it is not worth it. A more aggressive cam will give you more gain. However, if you have a standard exhaust, too much overlap may make the engine ingest water at low RPM or when you stop.
gonzocl is offline
Old 03-11-2012 | 09:33 PM
Hate to say it being I'm always for any upgrade but unless you plan on doing everything else save your money.
f_inscreenname is offline
