jetting quadrajet for new exhaust >
Old 03-09-2012 | 06:49 PM
Default jetting quadrajet for new exhaust
Hey guys, I have a totally stock gen v 454 magnum with a quadrajet carb. I am installing some 496 exhaust manifolds and risers on it and getting rid of the stock exhaust. Does anyone know if I will have to rejet the carb.
hadleycat is offline
Old 03-10-2012 | 01:10 AM
It will be fine without changing anything on the carb.
Griff is offline
Old 03-11-2012 | 08:59 AM
True what Griff said but are you sure it's a Rochester Quadrajet?
Those engines came stock with Weber carbs and the 454 magnum was jetted slightly different than the 454.
NightHawk is offline
Old 03-11-2012 | 09:22 AM
GPM
You might want to check the plug color before adding the new exhaust and at several different RPM ranges after, just to make sure you don't run lean. I believe Edelbrock has a tuning kit with a chart for enrichment that would help.
GPM is offline
Old 03-11-2012 | 09:38 AM
Thanks guys, I planned on doing some plug checks. I am pretty sure it is a Quadrajet. I am going to go take a look at it now, you've got me wondering!
Old 03-11-2012 | 09:58 AM
GPM
The carb on my 1995 Gen V 454 mag looked like this, yours may be different. http://www.marinecarburetor.com/Y43MercruiserOMC.htm
GPM is offline
Old 04-08-2012 | 09:56 AM
Just checked it is indeed a Quadrajet on a high rise aluminum intake
