Which wire is NMEA on Garmin?
I'm trying to wire my Garmin street pilot 3 to my livorsi GPS speedo. The Garmin has a DB9 monitor type plug as the output cable so I bought a plug to connect to that but need to know which wires to connect to it. Which position on the DB9 plug is the NMEA+? After that which wire do I connect to the livorsi gauge? I figured I would just cut the plug off the livorsi gps puck.
http://www.offshoreonly.com/forums/g...ps-output.html
I think this might be it as long as its an industry standard
contact direction (GPS) signal level description
1 output CD RS232 wire selectable 1PPS
2 output TXD RS232 NMEA data port output
3 input RXD RS232 NMEA data port input
4 not connected
5 both ground 0 V ground
6 output DSR RS232 wire selectable 1PPS
7 not connected
8 output CTS RS232 wire selectable 1PPS
9 not connected
Yes that sounds right. Looks like pin 2,3, and 5 http://www8.garmin.com/specs/pcwiring.pdf
Oops, sorry.
