camshaft suggestion >
camshaft suggestion
camshaft suggestion
Old 03-14-2012 | 08:09 PM
Default camshaft suggestion
I have looked for a crane roler camshaft and a rep of Crane cam suggest me a grind that I am not able to optain.
What can you suggest for the best all arond performance.
This is my prospect setup for this summer:
525sc upgrade to B&M 250 blower want to boost 7-8 psi.
460ci, single 1050 carb (525sc carb)
7,7:1 comp ratio on aluminium performer rpm Edelbrock head
Callies Compstar H beam rod
CMI (stock 525sc headers gen 6) wet exhaust.
I have look some other crane cam no 168731 - 168791 - 168761 and the 168741.
I dont know if the 168741 is to much cam for that setup any help and recommandation will be apreciate.
supermx96 is offline
Old 03-14-2012 | 08:43 PM
I ran a Blower Shop 250 Blower with 9 pound of boost on a Gen VI 540 a while back with the 741 cam in the motor and I will tell you...the motor came alive with the blower and that cam...especially at over 4000 rpm. I dont think you will have too much by using the same 741 cam in your 502.
pslonaker is offline
Old 03-14-2012 | 08:47 PM
Contact rmbuilder. Bob Mandera of marine kinetiks.
Waveform is offline
Old 03-14-2012 | 10:08 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Word...585-654-8583 - Bob Madara = no guessing !!!
the deep is offline
Old 03-14-2012 | 10:10 PM
X2 on Madara, you'll spend slightly less than a Crane roller and have it designed specifically to your application. Bob's number is 585-654-8583
endeavour32 is offline
Old 03-14-2012 | 10:26 PM
Default fixx
x3,,bobs da man! the 741 is a good cam for the blower,,mild thunder runs that cam or cams with his blower set up's
FIXX is offline
Old 03-14-2012 | 10:39 PM
My cam is similar to the 741, but ground on a 114LSA. The duration and lift is very close. Mine are actually Crower grinds. They sounded very healthy for a 460CI. I dont know how much power mine made, they were never dynoed. But, I do know that with a 250 B&M, 7lbs of boost, they ran very well at 5500RPM. If I had to guess, around 650HP at 7lbs, maybe even a little more. I have Dart alum heads, and about 1 full point more compression than you do.
My new setup is fresh rebuilds, .060 over (was .030), same cams, but now B&M 420 blower. My goal is to underdrive the blower, for cooler temps and maybe a bit more power.
MILD THUNDER is offline
Old 03-14-2012 | 10:56 PM
Do you have dry or wet exhaust? I am afred with water reversion. The stock 525sc cam have an overlap of 4 deg at .050 and the 741 cam have 16 deg overlap at .050.
So i dont know how to determin when you can get a posibility of water reversion do you have some experiance with that?
Old 03-14-2012 | 11:33 PM
I have dry tails now. But i did run the 741 with stainless marine wet tails before with no reversion issues.
Old 03-14-2012 | 11:59 PM
the deep's Avatar
Fast Singles Club
The next question should be at what point was the water injected into the exhaust stream , at the transom or farther up the pipe . Leave nothing to chance when it comes to possible reversion .
the deep is offline
