Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Paint engine assembled or not??? >
Old 03-16-2012 | 01:16 PM
onesickpantera's Avatar
Default Paint engine assembled or not???
I am getting closer to painting my engine and am not sure if I should do it assembled(heads, intake, etc) or disassembled.
I know if I do it disassemble I run the risk of chipping paint when tightening bolts.
But, the flip side is if I paint assembled and need to disassemble down the road(say remove intake) I am going to chip the paint around the bolt heads. Plus I like the look of non-painted bolt heads. I know it seems silly but it looks better IMO.
Opinions?
onesickpantera is offline
Old 03-16-2012 | 02:10 PM
scarabman's Avatar
Why are you into your motor? You didnt get the same disease Kirk had and you want to try and go as fast as I did in that boat?????
scarabman is offline
Old 03-16-2012 | 02:20 PM
Hah! No, the head gaskets were ready to be replaced so I decided to freshen everything. Believe me, I thought of what I could do to make it faster but common sense prevailed.
EDIT: Might have done a couple minor things.
Old 03-16-2012 | 04:14 PM
I painted with the heads on the block and the intake seperate. No biggie
POWERPLAY J is offline
Old 03-16-2012 | 04:25 PM
That's what I decided. Heads and oil pan on and painting accessories and intake separate.
Thanks.
Old 03-16-2012 | 04:30 PM
No problem. That is exactly how I did it. I trimmed the excess sealant from around the intake. Makes for a clean look.
Old 03-16-2012 | 05:14 PM
scarabman's Avatar
Shouldny be any other way. Be well
Old 03-19-2012 | 05:47 AM
what doesn't the paint make it faster?
dereknkathy is offline
