Empty trailer tire pressure
Old 03-17-2012 | 01:35 PM
ROADHOG's Avatar
Default Empty trailer tire pressure
Going to be pulling my empty dual axle trailer to Florida this week. Load range E tires that call for 90psi loaded. Can I run a lower tire pressure when empty to eliminate some of the bounce? Trailer empty has a weight of less than 3000lbs.
ROADHOG is offline
Old 03-17-2012 | 03:06 PM
Default fixx
sure, kepp them between 50/60 psi.
FIXX is offline
Old 03-17-2012 | 08:03 PM
hp500efi's Avatar
Member #9
Agree
Member of the Liquid Jungle
hp500efi is offline
Old 03-17-2012 | 08:07 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
You might want to take two wheels off as well.
Sydwayz is offline
