1991 240 Baja Bravo 1 big block cuddy need longblock >
Old 03-17-2012 | 03:11 PM
Default 1991 240 Baja Bravo 1 big block cuddy need longblock
This is a nice used 1991 baja, it only has 126 hours on it,
The good,
1. clean boat
2. 126 hours on bravo 1 drive- drive alone should be worth 2K- very low hours.
3. New trim pump and rebuild lift rams. so trim setup is basicly new.
4. interior isnt mint by any means, but useable as is.
5. Has a painted tandem trailer that matchs boat.
6. has trim tabs.
7. been in dry storage.
The bad,
1. Motor is all apart, bought a 525sc engine to replace the stock 330hp 454 and never happend.
So you get all electronics for engine, exhaust, marine oil pan, factory like new block. but will need rotating assembly, heads, and intake. If you buy a good longblock u can drive if after a wkend of work. 454 longsblocks are easy to find and you can always bolt a 502
Will get pics over weekend, i do have the title for it
grjdc1 is offline
Old 03-18-2012 | 09:11 PM
https://post.craigslist.org/k/snNtlW...4a2v?s=preview
Link that has pics for all that asked.
grjdc1 is offline
