what engines are these?
Old 03-17-2012 | 05:42 PM
Default what engines are these?
I am looking to buy a 1994 Envision Illusion 32 and I know it has (2) 454 mercruiser magnum 7.4 litre. I have the serial numbers ---- OF 12647 & OF 14020. I am hoping there is a way to find the H.P. of these engines and any other usefull info. Thanks
comanche22 is offline
Old 03-17-2012 | 06:13 PM
Too Stroked's Avatar
The regular 7.4 liter (454 CID) engines were 330 HP. The Magnum versions were 365 HP.
Too Stroked is offline
Old 03-19-2012 | 09:01 AM
Default mercruiser I.D. question
Is there a mercruiser site that will give manual for my engines if i have the serial number? Or do I need to look for the # on the block to get info from web pages. Thanks
Old 03-19-2012 | 09:53 AM
dougrussell.com
riverboater is offline
Old 03-19-2012 | 03:00 PM
Here is a fairly complete list of merc manuals.
#1 90-68648 1963-1973 Engines & Drives - All
#2 90-71707 1974-1977 Engines & Drives - All
#3 90-95693 1978-1984 Engines - All 4, L6 & V8
#4 90-86137 1978-1982 Sterndrives - MC 120 to 260
#5 90-12935 1978-1993 Sterndrives - TR & TRS
#6 90-12934--2 1983-1990 Sterndrives - R, MR, Alpha One & Alpha One SS
#7 90-12410 1983-1993 Engines - GM V6
#8 90-44553 1985-1989 Engines - Mercury Marine 4 Cyl.
#9 90-14499--1 1985-1988 Engines - GM V8
#10 90-14693--1 1985-1989 Engines - GM 4 Cyl.
#11 90-17431--4 1988-1998 Sterndrives - Bravo
#12 90-814099--1 1989-1993 Engines - Diesel, 5 & 6 Cyl.
#13 90-816462 1990-1997 Engines - GM 4 Cyl.
#14 90-818177--2 1991- Cur. Sterndrives - Alpha One Gen II
#15 90-816463 1989-1992 Engines - GM V8 (No Hi Perf.)
#16 90-823224--2 1993-1997 Engines - GM V8 454 & 502 CID (Gen V - Gen VI)
#17 90-823225--1 1993-1997 Engines - GM V8 305 & 350 CID (5.0L 93-95)
#18 90-823226--1 1993-1997 Engines - GM V6 Gen II Balance Shaft
#19 90-823227 1994-1996 Engines - Diesel, V8, 7.3L (IDI)
#20 90-823228 1994-1998 Sterndrive - Blackhawk
#21 90-806934 1994 - Engines - Diesel, 5 & 6 Cyl. 3.0L, 3.6L & 4.2L (IDI)
#22 90-860074 1997 - Engines - Diesel, D-Tronic 2.8L and 4.2L (DI)
#23 90-861326--1 1998 - Engines - GM V8 454 & 502 CID (Gen VI and L-29)
#24 90-861327--1 1998 - Engines - GM V8 305 & 350 CID
Suppliment 90-861327000 1998 - Engines - GM V8 377 CID (6.2L)
#25 90-861328--1 1998 - Engines - GM V6
#26 90-861329--1 1998 - Engines - GM 4 Cyl.
#27 90-861784 1998 - Engines - V-8 Diesel, D7.3L D-Tronic (DI)
Suppliment 90-861784990 1998 - Engines - V-8Diesel D7.3L D-Tronic & D-Tronic LD
#28 90-863160 1999 - Sterndrive#65533;Bravo One-Two-Three & XZ/XR
#29 90-860316 All D1.7L DTI In-Line Diesel (available early 2001)
#30 90-863161 1998- Engines - 496 CID/8.1L Gasoline Engine
#31 90-864260 2001- Engines - 5.0L (305), 5.7L (350), and 6.2L (377)
#32 90-864261 2001- Engines - 4.3L (262)
#33 90-863757--1 2001- Engines - PCM555 Diagnostics
HP #1 90-817110 1989-1992 Engines - Hi-Performance (Mark IV
HP420/HP425/HP465, HP500 Bulldog, HP575)
HP #2 90-815526 1982 - Sterndrives - III & II, III, IV & V SSM
HP #2
Suppliment 90-849776 All Sterndrives - III A
HP #3 90-848294-1 1992-1998 Engines - Hi-Performance (Gen V HP425/HP450/HP465/HP500,
Mark IV & Gen V HP525SC & HP600SC, HP 800SC)
HP #4 90-848656 All Sterndrives - VI & VII (Non Dry Sump)
HP #5 90-840250 1999- Sterndrives - VI (Dry Sump)
HP #6 90-840283 1999- HP500 EFI
HP #7 90-840500 1999- Engines - HP377 EFI
glenncal1 is offline
