OPTX Marine LED / StreetGlow / Liquid Trends Coast to Coast Tour >
Old 03-17-2012 | 08:53 PM
AKA "BAZOOKA JOE"
Default OPTX Marine LED / StreetGlow / Liquid Trends Coast to Coast Tour
check out the OPTX Marine LED Coast to Coast Tour at http://www.12voltnews.com/?p=36479 and optxmarine.com
bojoe2 is offline
Old 03-17-2012 | 08:54 PM
AKA "BAZOOKA JOE"
OPTX Marine has all kinds of LED lights for the cockpit, csbin and engine compartment pretty cool product
bojoe2 is offline
Old 03-17-2012 | 09:28 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
I just installed 12 LEDS today for the cockpit of my cruiser, purchased thru Marinebeam.
Doing a lot of research on LEDS, one of the key factors to look for are bulbs that are stated to cover a range of voltage, such as 9-30v. These all will have a constant current feature. The plain 12v rated ones can possibly burn up with higher voltage, common with boats plugged into shore power with battery charger that ramps up to 14v or so for initial charge step. Seen a video on You Tube showing this, a standard rated 12v LED started smoking within a minute, then burned out. These LEDS will usually cost more though. My 12 LEDS were $165. Being plugged into shorepower full time, worth the piece of mind. For your non charger equipped boats or cars, usually not an issue.
Just a little did bit.
US1 Fountain is offline
Old 03-17-2012 | 10:23 PM
AKA "BAZOOKA JOE"
US1 yes OPTX LED is rated 9 - 14 volts I also know a 30 volt rated LED only receiving 12 volts is starving the Diode so you will not get 100% lumens out of the LED. But you are correct about the LED that are 12 volt rated with no range.
bojoe2 is offline
Old 03-18-2012 | 07:51 AM
SHARKEY-IMAGES's Avatar
OSO Content Provider
Commercial Members
Thumbs up
Lit up by OPTX Marine:
www.TimSharkey.com/
Digital Photography & Video one BYTE at a time !
SHARKEY-IMAGES is offline
Old 03-18-2012 | 10:57 AM
Ginger or Mary Ann?
Are you affiliated with Optxmax? Looking at the Ultra Slim blue flexible ropes and seems blue is a hot item.
Old 03-18-2012 | 06:00 PM
Tom A.'s Avatar
Yes he is. Send him a PM and he will get back to you. If you don't here from him by tomorrow, PM me you number and I will pass it on. I am a close friend of his.
Tom A. is offline
Old 03-18-2012 | 07:23 PM
Ginger or Mary Ann?
We've been in contact. Thanks
Old 03-19-2012 | 04:00 PM
C_Spray's Avatar
Diamond Member #001
I installed some 18" OPTX strips on the underside of my engine hatch. They were really easy to install, and work really well. Thank you, OPTX - I'll be installing a whole set in my other boat shortly!
Attached Thumbnails OPTX Marine LED / StreetGlow / Liquid Trends Coast to Coast Tour-optxsunpad.jpg   OPTX Marine LED / StreetGlow / Liquid Trends Coast to Coast Tour-optxsunpadb.jpg
C_Spray is offline
