Where is the oil cooler?
Old 03-19-2012 | 10:05 AM
Default Where is the oil cooler?
Got a 98 34 Powerquest with 502 mpi/efi. Where is the oil cooler at?????
zschaefer38 is offline
Old 03-19-2012 | 10:40 AM
Randy Nielsen's Avatar
I have a 2000 eliminator with a 502 efi motor, the oil cooler on mine is right under the oil filter mounted verticly & the p/s cooler is right above the bellhousing. If you still cant find it just follow the lines from the oil filter back. Randy
Randy Nielsen is offline
Old 03-19-2012 | 10:43 AM
I will check again. Good results with your efi's so far?
Old 03-19-2012 | 11:50 AM
I have a whipple stage 3 setup going together for my eliminator not completely together yet
