Which Distributor should i go with? >
Old 03-20-2012 | 09:28 PM
Default Which Distributor should i go with?
What kind of distributor are you using? I understand that MSD is the top dog but are there any other alternatives? I have a Chevy 502 and it has a MSD on it but will not work. We switched it out with a regular chevy distributor and it works just fine. I looked at the manufacture date code on my MSD and it says that it was made in 1994. That seems pretty old to me. Should i send it to them to have it repaired or should i buy new?
I am basically looking for options, so what do you have for me?
Fountain Family is offline
Old 03-21-2012 | 06:36 AM
Mallory is pretty good. I had both engines in my Roamer switched over to Mallory's when i had it. Rock solid, easy to get parts for and easy to mod.
Redhook98 is offline
Old 03-21-2012 | 07:33 AM
offshoredrillin's Avatar
check out davis unified ignition or DUI, i had them on some street cars and really liked them, never tried their marine stuff though.
http://www.performancedistributors.com/
offshoredrillin is offline
Old 03-21-2012 | 07:53 AM
bcfountain's Avatar
Registered User
which msd are you running?the one that uses a box or a ready to run distribtor?
bcfountain is offline
Old 03-21-2012 | 08:09 AM
It is the MSD with the Rev limiter box and ignition control box. It also has the coil.
Old 03-21-2012 | 08:17 AM
i know the msd box does not last forever,but it is the most common for a reason,i would get a new box,and a new coil,then you will be good to go for a long time.
mike tkach is offline
Old 03-21-2012 | 09:31 AM
Use a mercury ignition like thunderbolt or what they use for 500HP's.
TexomaPowerboater is offline
Old 03-21-2012 | 09:40 AM
737jetmech's Avatar
Been running the DUI 's for 3 season ... built in adjustable rev limiters and no boxes to fail . I will never run a MSD's again .
737jetmech is offline
Old 03-21-2012 | 09:51 AM
The MSD i took out of the motor had a Bronze gear at the bottom. If i went with the DUI would i have to switch it out?
Old 03-21-2012 | 10:12 AM
737jetmech's Avatar
Yes ! They can send you one with a bronze gear . They are easy to work with ... and a quick turnaround . The limiters cost extra ... standard marine unit cost around $318 . All you have to connect is a tach wire and a power lead .
I got tired of having to carry a spare msd box on the boat .
