Help removing mildew/ mold of vinyle >
Old 03-22-2012 | 05:47 PM
Default Help removing mildew/ mold of vinyle
I have some mildew/mold on my vinyle and wanted to know what have you guys used to remove it....is there a special product I can buy at west marine/ home depot...or mix to products together. Thanks in advance
SkaterMike82 is offline
Old 03-22-2012 | 06:14 PM
Lightbulb
try Spray 9 before shelling out $$$ for speciality products.
spectras only is offline
Old 03-22-2012 | 06:24 PM
Roll off and Magic Eraser. Make sure you try it somewhere out of the way first so that if it changes color or anything it will not be seen.
Perlmudder is offline
Old 03-22-2012 | 06:31 PM
The vinyle is pretty much all white....I don't care about spending money on something that you guys have used in the pass that has worked
Old 03-22-2012 | 06:39 PM
Originally Posted by spectras only
try spray 9 before shelling out $$$ for speciality products.
+1
rj45 is offline
Old 03-22-2012 | 07:35 PM
What about stains on white vinyl? I've got some stains that look like rust filled water dried on the seats. Any suggestions? I've tried the 303 and it hasn't worked.
WildRooster is offline
Old 03-22-2012 | 07:53 PM
sunchaser796's Avatar
Any time you use spray nine on the vinyl, wash it down with water, dry it out the best you can and wipe it down with low oder mineral spirits then go back over with a dry cloth. You can also use bleach diluted. Spray nine and bleach removes the natural oil from the vinyl.
sunchaser796 is offline
Old 03-22-2012 | 07:58 PM
magic eraser really are magic. they take crud off you never thought possible. they make a lazy dudes job easy. watch out on vinyl it can take some of the material with it if its getting aged...
roughwater is offline
Old 03-22-2012 | 09:33 PM
Mentalpause's Avatar
Fountain of Youth products work great. Hit the instructions tab and they have some videos demoing some of their products.
http://www.fountainofyouthrestore.co..._Products.html
Mentalpause is offline
Old 03-22-2012 | 09:40 PM
+1 on spray 9 and magic eraser
gotstreetracin is offline
