sbc high oil pressure
On my ski boats 350 last year before winterizing it I was changing the oil and accidently filled it with 20w-50 when I started it I noticed higher than normal oil pressure. I thought no big deal next year I'll put in 10w–30 and it will be normal. So this year comes I change the oil and the pressure is still high 55 at idle and over 90 if I rev it.
Ive tried two different mechanical gages
Tried installing a new oil pump and filter bypass
The motor has 120 hours runs like a top and had zero shavings in the pan
Im thinking a bearing has spun and is bloccking an oil hole
Any advice?
what route does the oil take? Cam or crank first
Any advice?
Any advice?
Any advice?
Yoda,
Which oil pump did you use ? The filter bypass really has nothing to do with oil pressure. If you are "truly" getting 90 lbs, I would think that the bypass valve in the pump is stuck shut, unless you used some type of high pressure pump, but even those dont generally make 90lbs.
Yup, I know, its a new pump, but that dont mean squat.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Bill Koustenis
Waldorf Md
I just pulled it apart mains and rods look like the day I put them in. I think I'm going to put in a used pump I have here just to see what happens. Both pumps are melling the original was a high volume. The new one is a standard flow m-55
Thanks for the responses
Neil
Neil
I've been thinking about the relief valve on the pump if it was stuck closed wouldn't I only see high pressure at higher rpms? Or is the relief valve opening all the time on a normal engine.
did the pump come with another spring? usually the pump comes with the high pressure spring installed already..if it came with the extra spring then take i think the purple one out and install the lower pressure yellow spring,,this should give you cold 60 psi and 25 psi hot at idle..
