how many psi on a blower you need to make 750 hp out of a 502 bbc with 525 hp >
Old 03-24-2012 | 09:54 AM
Default how many psi on a blower you need to make 750 hp out of a 502 bbc with 525 hp
I was just wondering, i have 502 bbc motors making around 525 hp and looking to get around 750 out of em. With a 671 blower and no intercooler how many psi would i need. And would motors still be reliable
slippy0217 is offline
Old 03-24-2012 | 10:48 AM
There's a lot more to the equation, what heads? Cams? Injected or carb?
Unlimited jd is offline
Old 03-24-2012 | 10:57 AM
onesickpantera's Avatar
My buddy has a Gen VI 502 mag MPI that made 730hp on Crockett's dyno.
I know the heads had better valves installed but the cam used was very mild.
He's running a M1 procharger with @ 5lbs.
onesickpantera is offline
Old 03-24-2012 | 10:59 AM
its go be carb and the heads are iron wit a little work done to them as far as the cam i dont know would have to call innovation marine
i just looking roughly 8 psi would give how many more hp
Old 03-24-2012 | 11:04 AM
What Innovation engine are you running?
Old 03-24-2012 | 11:39 AM
sean stinson's Avatar
The Illustrious One
Veteran: Navy
I believe a rule of thumb with everything coinciding with one another (carbs, cams, heads, and so forth) its about 30 hp to 1 lb of boost.....I THINK....that's what I remember to get to 1250 from 800 which was also an Innovation Engine!!!!
Dying,....Is the day worth living for!!!!!!
sean stinson is offline
Old 03-24-2012 | 12:02 PM
the innovation marine 525 it was almost identicial as the old volvo 525 that innovation marine built
Old 03-25-2012 | 08:37 AM
axapowell's Avatar
Where To
ALL things being perfect...36hp per pound of boost. 30-33 is average. So, you arencorrect!
Dave
axapowell is offline
Old 03-25-2012 | 06:42 PM
SB
HP per each boost psi is always going to be the biggest just into boost. IE: Your 1st 5 pounds will be more hp per psi boost than say going from 10-15psi.
Edit in: Each psi and each hp per psi is 1 million % dependent on engine size and build and SC and intercooler effeciency and so on and so on.
SB is offline
Old 03-27-2012 | 07:21 AM
not all blowers are going to be equal, not even close...with a procharger 7lbs should be close, maybe a little less...with a 671 10 at least I would think...
ezstriper is offline
