Go Back  Offshoreonly.com > Owners Forum > Saber
WW is Going >
WW is Going
WW is Going
Old 03-26-2012 | 10:32 AM
Default WW is Going
To Whipples and fuel injection!
Dan Adams is offline
Old 03-26-2012 | 12:35 PM
littledcsrodshop's Avatar
Congrats !! I know you had been wrestling with the decision for a while now, I'm sure you guys will get er right..
You going with 5.0 litre's ?? Are you comming in from the top with 2 throttle bodies, or comming in from the rear.. ?? (go ahead everybody fire away since I said "comming in from the rear")
I was really hopping when I seen the title of the thread that it was gonna say the boat was headed to TN for as an early birthday present..
littledcsrodshop is offline
Old 03-26-2012 | 12:53 PM
Sweet.
drpete3 is offline
Old 03-26-2012 | 02:02 PM
Cant wait to see the changes! FI is the way to go if you have someone to map and program it right. You hear a lot of good things about Whipples, what do you expect to gain over the current setup?
hotjava66 is offline
Old 03-26-2012 | 02:26 PM
Hoping to gain consistancy. The old 14-71s and dominators loved the last run of the season but the air and water were really cold. Hot days she would be all over the knock meters even with 50-50 mix of race fuel and 93. I will try to afford new chillers to, have to see how the budget goes. I hear the gains parasitic loss are around 100 to 150 hp.
Old 03-26-2012 | 05:48 PM
Wrestling, good word for dang this chit is expensive!
Yep, found some 5.0s with the back side fi. Ok Scotty, "coming in the rear"
Old 03-27-2012 | 05:15 AM
boatme's Avatar
Dan
Ever consider Turbos on that bad boy ??
Would also be a cool project
boatme is offline
Old 03-27-2012 | 11:19 AM
Mark,
Sure, I'll take two Earhart 1500 T.T.s ! ! !... oh I would have to pay for them?
Old 03-27-2012 | 01:59 PM
kcsteve124's Avatar
Dan, Congrats on your project for WW, please keep us informed on how it's going all the way to the test runs.
kcsteve124 is offline
Old 03-27-2012 | 06:38 PM
AIR TIME's Avatar
Dan congrats also. hey how much boost where you running and compression. Dean has me at two choices, one set up is 8lbs one with 5lbs. if I race or pr with the #8 I need to mix fuel. or run 5lbs with 93octane. so I like to here what your running with the 14/71. thanks man I would love to own a 41 with GELLNER or RIED power. but would need the wife to get a BIG RAISE or hit POWER BALL. I still need a min of 3 surgeries lol. I am hoping to straighten out the porpoise this spring. by prop change/bottom change /hope not a CG since we don't know stock CG. I just want to run man, and see if I can bust some sutphen balls lol. good luck with the whipples efi's are nice set ups.. Art
AIR TIME is offline
