Questions about adding inside hydraulic steering >
Old 03-28-2012 | 09:53 PM
Default Questions about adding inside hydraulic steering
I'm in the process of removing my old mechanical helm and cable to install the inside hydraulic system. I currently have an add on system by Marine Machine. I'm looking at purchasing one of two systems CP Performance has for sale. One is the basic kit, the other the deluxe. The difference being the deluxe uses an external power steering resevoir, the basic not. CP wants me to use the deluxe, but it's just going to be a more complex install and I also have limited options for mounting the resevoir and making it higher than the stock pump with my shallow boat.
I have a buddy with a 26 velocity with full hydraulic and he does not have the remote resevoir, but I believe he has only one external ram vs. my 2 ram single drive. Just looking for additional opinions on adding the hydraulic inside kit with or without the additional resevoir. Thanks.
cloudmaster_321 is offline
Old 03-28-2012 | 09:59 PM
c_deezy's Avatar
You don't need the add-on external reservoir.
Installed the dual ram Mayfair system, and removed the external reservoir and had no issue. Full hydro to the helm.
c_deezy is offline
Old 03-29-2012 | 09:37 AM
swan2's Avatar
Hey there Cloudmaster im in the process of ordereing the dual ram single outdrive addon kit and do the inside later. My question is how well did this work, and could you tell a big difference when you installed the add on??? I dont have the money to do the completed system right now thanks for the help.
swan2 is offline
Old 03-29-2012 | 03:54 PM
I didn't drive the boat with the stock system. I bought the boat used, and it already had the Marine Machine add on system. I can tell you one thing though, coming into the docks can be tricky as the steering at idle is stiff and your not able to make quick corrections. I'm hoping the full system will rectify that.
Old 03-29-2012 | 05:24 PM
swan2's Avatar
Thanks for the reply back. I think im going to give it a try like I said im unable to purchase it all at one time. One more question did the steering seem tight at higher speeds? I have already had my gimble and all the bellows replaced just want to tighten things up and have a little more control as my boat does reach the 80mph mark on gps. since I have added more hp.. again thank you for replying.
swan2 is offline
Old 03-29-2012 | 09:49 PM
oh yeah, it's definately stable and tight at speed. No problems there; granted your mechanical helm and cable are good.......
Old 03-30-2012 | 09:22 AM
I just did the same thing....used their std kit..BUT you will need the tool to do the line ends..trust me !!! also some machine marine uses a different size inside fitting to ck sizes before ordering...
ezstriper is offline
Old 03-30-2012 | 09:58 AM
swan2's Avatar
Thanks guys I will be ordering my kit soon and trying it out cant wait. Ill let you all know how it turns out. will be doing the job myself to try and save some money.
swan2 is offline
Old 03-30-2012 | 10:26 AM
Yeah, I already have the -6 AN mandrel for making lines here at work. So that will make it easy. Pretty common stuff for aircraft fittings.
You didn't get talked into the deluxe kit with the resevoir?
Old 04-18-2012 | 07:10 PM
ROB FREEMAN's Avatar
just a thought . you probably can fix the stiffness by enlarging the power steering pump orfice ?? helps move more fluid at low rpm , just trying to help
ROB FREEMAN is offline
