Where Do I get? Dash Rocker Switch Covers  with Labeling on them? >
Old 03-29-2012 | 09:36 PM
Strip Poker 388's Avatar
Rob
Question Where Do I get? Dash Rocker Switch Covers with Labeling on them?
Help Please.I'm trying to find the covers with the labeling/lettering/ silk screening on them.Does anybody know or suggest were I can find them?
Also I'm thinking I could tape off the lettering and spray some clear on the new ones? Or clear nail polish? I keep cleaning the lettering off them
I have the black ones with the white legends/lettering. It looks like I have the CONTURA III switch w/ Embedded LEDs. Or the Cole Hersee 58332 style http://www.colehersee.com/home/grid/cat/9/
I wonder if the style II 2 will interchange???
I did some searching and found alittle on them, but not the same lettering.
Rob
heres some links I found,maybe they'll help someone else on diff styles.
http://www.cmsquick.com/prod_17_S_RocA.html#rocv_III
http://greatlakesskipper.com/product...eywords=switch
close
http://greatlakesskipper.com/product...witch-set.html
style II
http://www.pacergroup.net/Categories...ened_Actuators
they have alot of wireing stuff!!!
http://bluesea.com/category/8/33/pro...e/overview/147
blank cover here for 1.80 http://order.waytekwire.com/productd...II%20ACTUATOR/
http://order.waytekwire.com/products...itch/Switches/
diff style switch
http://www.mastervolt.com/marine/pro...nated-legends/
Attached Thumbnails Where Do I get? Dash Rocker Switch Covers  with Labeling on them?-rocker-switch-covers-006-large-.jpg   Where Do I get? Dash Rocker Switch Covers  with Labeling on them?-canon-d-7-test-042-large-.jpg   Where Do I get? Dash Rocker Switch Covers  with Labeling on them?-switch-1-large-.jpg
Strip Poker 388 is offline
Old 03-29-2012 | 09:38 PM
Rob
pic 2
http://i19.photobucket.com/albums/b1...g/1158d409.jpg
Attached Thumbnails Where Do I get? Dash Rocker Switch Covers  with Labeling on them?-switch-2-large-.jpg
Old 03-29-2012 | 10:51 PM
Default fixx
eddie marine can lazer etch the panel then you can put blank switch's in,this way you wont ware out the lables on the switch's!..
FIXX is offline
Old 03-29-2012 | 11:36 PM
Loos like Cole Hersee or Carling Switch, The problem is not sure if the switch is standard (with labeling) You might have a minimum quantity. Expecially with Cole Hersee They just moved there factory at the end of last year, and now have high MIN's, Even if you go to a Distributor you might get hit with a min,
rfgonzo is offline
Old 03-30-2012 | 08:57 AM
Mindi
Send us an email with what you need Rob, we can get them...
[email protected]
Doller Offshore is offline
Old 03-30-2012 | 10:41 AM
Rookie's Avatar
Just keep on surfing that site. I think you can find them.
http://greatlakesskipper.com/categor...ch-plates.html
Rookie is offline
Old 03-30-2012 | 03:16 PM
Been looking for at least a year. Great Lakes has a couple but not all of them. I'll try doller myself.
Skullkrusher is offline
Old 03-30-2012 | 05:55 PM
Rob
Thanks for the replies,I think I found one place that has some.They would custom make them to what I wanted .but theres a set up charge for the Pad/silk screening.
Pacer Group
Sarasota, FL 34240
Doller Offshore I'll give ya a call if they don't have all of them,thanks
Rookie I didn't see the flat style on there site,most was Baja stuff ,I called them they weren't very helpful, also the have allot listed on ebay
Rob
Old 03-30-2012 | 06:52 PM
Rob,
I used to sell these carling switches. I ended up having some labels printed that you just peel and stick... I can forward some to you cheap... let me know if you are interested..
Attached Thumbnails Where Do I get? Dash Rocker Switch Covers  with Labeling on them?-dsc02173.jpg   Where Do I get? Dash Rocker Switch Covers  with Labeling on them?-switch-panel-labels1.jpg   Where Do I get? Dash Rocker Switch Covers  with Labeling on them?-dsc02177.jpg
Where Do I get? Dash Rocker Switch Covers  with Labeling on them?-switch-panel-labels2.jpg
teamsynergy is offline
Old 12-25-2013 | 08:43 AM
I know this thread is old, I am looking to wrap my switch panel on a 24 outlaw and need either switch covers with the labels on them, or the labels so I can out on the switches. Have been looking for a while and have t come up with too much. What did you end up going with? Or does anyone that offered assistance still have these available?
ealesh33 is offline
