what causes a knocking sound? >
Old 06-25-2002 | 05:19 PM
HappyOurs
Question what causes a knocking sound?
We just put a BRAND NEW Merc. motor in our boat. It starts right up, purrs like a kitten. However, when we accelerate, there's a terrible knocking sound. We haven't run any higher than about 3500-4000 RPMs since it's a new motor and we're breaking it in. Runs fine when we're just cruising around, however, when we tried to pull a tuber, the motor was cutting out or missing, and we were not able to pull a tuber or skier. The mechanic first thought it was a problem with a valve, possibly a "floating valve," but checked that out and there seems to be no problem with a valve. Any ideas of what it could be?
Old 06-25-2002 | 05:52 PM
Brad Perry
That sound is the mechanic's helper, still in the bilge, banging the side of the boat with a monkey wrench.
Old 06-25-2002 | 06:08 PM
HappyOurs
At this point I would believe anything!!
Old 06-25-2002 | 07:02 PM
From: Lakeway, TX (Austin/Lake Travis) / LOTO Gravois Arm
So, it seems to be knocking mostly when under load from a skiier or tuber and trying to plane? Or, is it knocking all the time?
In2Deep is offline
Old 06-25-2002 | 09:06 PM
Vinny P's Avatar
I hate the winter!!
What motor did you install? Was it a complete bobtail? What happens if you rev the motor a little in nuetral? I am just curious, how did the mechanic check for valve float?
Vinny P is offline
Old 06-25-2002 | 09:17 PM
blue thunder's Avatar
You are omitting valuable info happyours. What is the oil pressure, water temp, what type of outdrive, what rpm is the noise first notice and when does it stop. We need more input dude.
BT
blue thunder is offline
Old 06-25-2002 | 09:20 PM
HappyOurs
It was a Merc. 5.0 liter V8 Vortec. Did not replace the outdrive. Not sure how he checked for floating valve. We didn't try to rev in neutral.
Old 06-25-2002 | 09:26 PM
HappyOurs
The oil pressure was fine, water temp was fine, we've got an Alpha I outdrive. The popping noise starts at around 2700 rpm and doesn't stop after that; however, if we're not towing, the boat runs fine other than the loud knocking/popping sound.
Old 06-25-2002 | 11:08 PM
MitchStellin's Avatar
It sounds like your Cam is going. If it is a load popping out the exhaust that is probably it. The knocking is probably the pushrod and lifter and rocker arm. and and and and and............
MitchStellin is offline
Old 06-26-2002 | 07:26 AM
Scott72
Also check to make sure your rockers are tight. I just had my engine rebuilt and one of my roller rockers came lose after 2 hours (don't think it was adjusted correctly to begain with). Made a real good knocking sound up around 3000.
