any one have any stock headbolts for big blocks >
Old 04-05-2012 | 09:14 PM
Default any one have any stock headbolts for big blocks
i need one headbolt its the medium length one on the ends inside the valvecover. ive lost one from a set ..
just a stock bolt is what i need oldskool 454 mark block.
jason y is offline
Old 04-05-2012 | 09:23 PM
O.C.Barry's Avatar
Default Bolt
Jason - If you can give me the length, I'll check to see if i have one, If I do, you can have it.
Thanks, Barry
Driver - High's Fuel Your Journey Cigarette Racing Team #598
O.C.Barry is offline
Old 04-05-2012 | 09:32 PM
ive got a box full i'll check in the a.m. make sure there ok and not rotted i can send you 1 of each size to make sure you get what you need
Unlimited jd is offline
Old 04-05-2012 | 09:39 PM
GREAT ill get my sets out tomorrow and wire wheel em down and make sure there all good and let your guys know exactly what i need... THANKS GUYS
jason y is offline
Old 04-06-2012 | 12:17 PM
If they are that rusted and/or corroded, they should be replaced. These are fairly important holding devices. And, a complete set for both heads are not that expensive. Jegs and Summit has them in stock too.
ROTAX454 is offline
Old 04-21-2012 | 12:20 PM
still need to take care of this if any one has any I need at least one long one as that is what i miss placed i could use a few more as the heads on some are a lil pitted there still usable though if it comes down to it
jason y is offline
Old 04-22-2012 | 10:35 AM
O.C.Barry's Avatar
Default Bolt length
Jason - If you post the bolt length you need. I'll check.
Thanks, Barry
Old 04-22-2012 | 10:39 AM
Default headbolts
Bought a set this winter from headbolts.com about 40 bucks check their website
bunky1957 is offline
Old 04-30-2012 | 10:26 PM
Default set of big block chev used headbolts
I have a used set of big block mark 4 head bolts that you can have for free. just pay shipping.
1983corsa31 is offline
Old 05-01-2012 | 08:37 PM
New is $8, shipping from these fine fellas will be $10 min. Might as well get a whole set!
Andy is offline
