Go Back  Offshoreonly.com > Boating by Region > Midwest
Engine Dyno near KC? >
Old 04-08-2012 | 08:56 PM
Default Engine Dyno near KC?
I'm in OP, and wanting to get my new engine on the dyno for fine tuning before I drop it in my Velocity.
Here are the specs
Block-
Decked
Align Honed
Bored .060 over
Steam holes drilled
Bore notched
Rotating assembly:
GM Forged Crank, NOS 3.76 Stroke
Eagle H Beam Rods- Resized at Wesco
SRP Forged Domed Pistons
ATI Super Damper
Valve Train:
AFR 265 Oval Port Heads CNC Chambers, inconel Exhaust Valves
Morel Roller Lifters
Scorpion Endurance Marine Rockers
Marine Kinetics Roller Cam
234/240 .63/.61
Fuel System:
Weiand Stealth Intake
Pro Systems HP Holley, 830 CFM
Holley Marine Fuel Pump
and I've got Stainless Marine GenIII exhaust
Waveform is offline
Old 04-08-2012 | 09:59 PM
1980Condor460's Avatar
If it was me I would probably drive it down to Smith Power in Joplin. 417-499-7855.
1980Condor460 is offline
Old 04-09-2012 | 05:16 PM
Is there anyone closer or cheaper. Unexpected Transom replacement has put a large dent in my funds.
Waveform is offline
Old 04-09-2012 | 09:50 PM
carter38's Avatar
Brad is very reasonable more so than you think. Call him it will be set up right.
carter38 is offline
Old 04-09-2012 | 11:07 PM
I did call, its 500. Never paid to have a motor tuned, don't know if that's reasonable or not.
Waveform is offline
Old 04-09-2012 | 11:56 PM
carter38's Avatar
Very reasonable. I had quotes around my house for 700 just to put on the dyno without tuning. It will be the best 500 you've spent to know it's right and all you have to do is drop it in after that. Peace of mind is nice to have.
carter38 is offline
Old 04-10-2012 | 05:48 AM
Call Yancy in Smithville.
tbirdusa is offline
Old 04-10-2012 | 12:21 PM
Knot 4 Me's Avatar
$500 is very reasonable.
Knot 4 Me is offline
Old 04-10-2012 | 01:00 PM
That is VERY reasonable.
Griff is offline
Old 04-10-2012 | 06:06 PM
have dts 4000 engine dyno in Wichita and 2 chassis dynos
tunertech is offline
