Header Choices
I'm a little confused on what headers to run on a new setup. There is a lot of two sided views on the same product on this site. You hear the horror stories along with nothing but good things on similar setups.
I have an old pair of Stainless Marine manifolds that I intended to run on a new pair of 572cu in w/ 420 megablowers. Problem is, they are used, and have been in salt water all their life. I will take reliability over HP and would like a little advice from experienced users. I am a little nervous to use these, not worth it if there is a catastrophe. Also, I'm very nervous to buy a new set as I have heard of major catastrophes.
Any advice?
Any advice?
Thanks for the advice. Are you saying the Stellings are not a good choice? I would almost rather have manifold style if they are on the safe side vs. a true header design that I have read about coming apart, leaking, etc.
we had a blown 502 whit stylings on them and bought it make 750 hp for a few years after rebuilding it at the same specs we get it on a super flow dyno and only see 675 hp ! Now the part you won't believe ,we swapped the stylings for a pair cast KE and we maked 800+ Hp after a few hours fine tuning it almost maked 900hp :eek drop:
We set it at 850 to keep it save but it was unbelievable U have to been there to believe it
I wish the made a set for ls small block !
On a 572 cubic inch well equipped blower engine the Stainless Marine HiTorque III system works very well also and a lot of performance boaters and big dollar boats have been using them successfully for years with good results and reasonable cost. The Kieth Eickert cast sweeper headers are great units too and as said here develop great power and torque, they just cost a little more with special tips and all.
Neither have a problem with leakage or breakage and seem very long lived with good maintenance and care.
You couldn't go wrong with either.
Best Regards,
Ray @ Raylar
Best Regards,
Ray @ Raylar
Best Regards,
Ray @ Raylar
Best Regards,
Ray @ Raylar
The KE cutaway pic is the old original header. Note in mine, KE no longer uses two water exit points. The rear boss area is left untouched. BTW. Having bungs welded into the tails for O2 sensors.
rotax is right on the KEs, I had to grind off the arp studs on the lower middle 2 fasteners to get the headers to clear. They are fine now though and I agree after almost 10yrs of running 2 sets of KEs they are the catz azz.
Yes, those are the KE headers I was referring to. I realize many cast manifolds and manifold headers will usually have a problem with clearance height on lower head row of ARP type studs as studs on this row are taller than head bolts and require more clearance that most all brands of cast manifolds do not have versus flange style tubular headers which generally do not have a head stud clearance problem at the same point. As you said the solution if pretty simple to keep existing studs or new ones in use on your engines. Glad to hear KE cleaned up the water transfer points near the tails is obviously looks cleaner on the new style.
Best Regards,
Ray @ Raylar
Best Regards,
Ray @ Raylar
) then go with either IMCO Power flow PLUS, or the SM Gen III manifolds.
