Go Back  Offshoreonly.com > Owners Forum > Donzi
454 or 350 >
454 or 350
454 or 350
Old 04-15-2012 | 06:55 AM
Craney's Avatar
Default 454 or 350
Freind just bought a 18' Donzi the boat came with a 454 gen 4 and a 350,it has a Bravo drive. What motor should he put in, and how fast will it run with each motor?
Craney is offline
Old 04-15-2012 | 08:00 AM
jeff32's Avatar
for an 18 footer, the 350 will be plenty power for general use... for a more ''racing or fast'' way to drive... 454 !!!
Can't tell the speeds ....
jeff32 is offline
Old 04-16-2012 | 08:06 AM
prostock3 is offline
Old 04-16-2012 | 03:55 PM
Fenderjack's Avatar
Pirate of the Chesapeake
Stock for stock, a big block in a smaller boat is cool. If you are building on a budget, you will be amazed at the power you can squeeze out of a small block.
John jr
Fenderjack is offline
Old 04-16-2012 | 06:20 PM
GB
18 Classic's are made for SBC/ 375-450hp +... period.
GB is offline
Old 04-26-2012 | 03:15 AM
The boat will handle way better with the SB!!! If both are equal in power the SB will not only handle better but be prolly faster due to less weight!
Something else to take into consideration is space while working in the bilge, a small block is pretty tight in there with the classic 18's low freeboard, yes the 454 will fit but will be even tighter. Spend a lil coin on the small block and you'll have a better handeling set up.
osur866 is offline
Old 04-26-2012 | 09:15 AM
Go with a 383 still a small block with a little more kick
ROADTOYS is offline
Old 04-26-2012 | 03:22 PM
Originally Posted by roadtoys
go with a 383 still a small block with a little more kick
+1.
MCKILLOP is offline
Old 04-26-2012 | 10:54 PM
GB
On the spot....
GB is offline
Old 04-27-2012 | 12:40 AM
Or go with a 383 run it for a couple years, put shorty, steering on then add a Whipple and run into the low 90's, what I did with mine
osur866 is offline
