Running a thermostat >
Old 04-15-2012 | 06:52 PM
Default Running a thermostat
How and is it important to run a thermostat? My boat is a 79' Scarab 300 with twin 330 hp bbc and TRS drives, I pull water in from the bottom of the boat, I guess it is considered an open system. I pulled the t stat housings off, the port engine had a stat, the starboard didn't, never heard of doing that, I've only owned the boat a couple years changing exhaust on the boat putting captains call on it trying to get it out of the
70's
BadBoy is offline
Old 04-15-2012 | 07:08 PM
seafordguy's Avatar
I don't have any stats. I always do make sure though that I get the oil temp up enough to boil off any water.
seafordguy is offline
Old 04-16-2012 | 05:30 AM
the problem with no t-stat. your block is too cool. it is designed to run at a certain temp. you will get rapid bore wear from too low an operating temp.
dereknkathy is offline
Old 04-16-2012 | 05:52 AM
as well as poor fuel economy and condensation.
NightHawk is offline
Old 04-16-2012 | 06:08 AM
Run the thermostats. They are there for a reason.
Redhook98 is offline
Old 04-16-2012 | 07:15 AM
OK, what temp do you need to run or do they only have one temp?
BadBoy is offline
Old 04-16-2012 | 08:43 AM
Guys around here been running big power supercharged big blocks in boats for many years without water thermostats. The reason for it is a cool block and heads means less chance of detonating.
However, in a 330HP 454, there really isnt a reason not to run stats. If you dont have oil thermostats, then put the water thermostats in. 140* stat is fine.
MILD THUNDER is offline
Old 04-16-2012 | 09:17 AM
I think efi and mpi's run at 160...
silent lucidity is offline
Old 04-16-2012 | 09:19 AM
I doubt his 1979 30ft scarab with 330's has MPI or any kind of EFI. The OE merc stat for his engine is probably a 143* merc unit.
Old 04-16-2012 | 01:22 PM
just q carbs no efi thanks guys. I have another ? I changed from the old log style exhaust manifolds to center rise, my thermostat housing is 2 parts, lower has outlet to the water pump (circulating pump) outlet to sea water pump 4 outlets to exhaust/riser, upper has 2 outlets to exhaust/riser.With center rise I only need 4 total. Is there a upper without outlets and still be able to run stat?
BadBoy is offline
