New boat build Questions
As some might know, I am in the process of a new build, I find my self adding additional upgrades all the time. I still have a few that I am considering like GPS touch screen, should I get this or just use a hand held? What about Auto Halon, I have had this in all my other boats but should I add this? How about a Dual Pro battery charger? can't I just use a trickle charger when at home? Any help or insight would be greatly appreciated.
If you feel you will use the options enough to justify the cost, then add them. If not, don't waste teh money. I don't see a reason to have a dual battery charger on board if the boat is mostly trailered.
Halon - good idea
GPS - A chartplotter is definitely a good idea. Personally I don't care for the touchscreens in a boat, too hard to use when you are bouncing around. I would recommend the traditional key scroll over the touch screen. Hard mounted over a handheld, but a handheld is good to keep along just in case.
Anything else you have to decide if its of a benefit to your or not. You can always add stuff later on.
If it was my boat I would do a GPS (not a touch screen because of the glare from your finger prints)....
The Halon, be greatfull you have never used one in the past; however, if the time came up that you needed to use one and didn't have it, you would be saying
I would recommend the battery charger as well because they are generally much better chargers than a standard trickle charger and will do "step down" charging which is important for some high end batteries to survive. The step down chargers will ususally start charging at 40A, then slow down to 20, 10, 5, 3, and 1 and charge each battery at the same time individually.
Agreed with above. Get a good, non-touch screen GPS. I currently am upgrading my boat to a Garmin 4208.
I also agree with an engine room extinguisher, one less thing to worry about.
Battery charger is also a great idea, I added one to my boat last year and plugged it in for all the poker runs and never once had to worry about a dead battery. It is nice to just run an extension cord to the boat and plug it in. I keep a HD 110 50' cord and a couple adapters to plug into any marina. I can run the lights, stereo, etc. all night and not worry.
Thanks for the info. I did go with the Halon and Battery charger, I'm gonna hold off on the touch screen GPS for now and get a non-touch. Also today I added the new Vantage View Gauges, Anchor locker, Fender Cleats, Billet Throttle and Remote for swim platform.
