trim tabs >
trim tabs
trim tabs
Old 04-16-2012 | 01:55 PM
Default trim tabs
I have 1997 24ft baja outlaw sst with 502 mag procharged. What size trim tabs do i need? Right now i have i think regular size tabs with w/dual hydraulic arms. Do I need k plans or what size tirm tabs do i need? The boat came with a set, not sure if they are the right size. The top speed of boat is 80mph.
please help
conneroutlaw is offline
Old 04-16-2012 | 02:07 PM
JasonSmith's Avatar
I would want them over the aluminum Benett style you probably have. As far as "needing" them, I don't think you need them, but you should want them. You "need" hydraulic steering if you don't have it already.
JasonSmith is offline
Old 04-16-2012 | 02:21 PM
Default tirm tabs
As we speak the full hydraulic steering system from imco is being order and installed. the boat came with the trim tabs on it. No info was given to me but , some one at the marina said i need bigger ones. just not sure what to do, this guy used to race boats.
Old 04-16-2012 | 02:45 PM
Dave M's Avatar
Veteran: Navy
Ideally you can run the boat at WOT without using any tab. If you have chine walk or any other ill handling, I would look at the steering or prop. Using the tabs will slow you down.
Dave M is offline
Old 04-16-2012 | 03:13 PM
In good water conditions my 25 ol runs the fastest with the tabs neutral. I am going to add 280 k-plans this summer.
violator is offline
Old 04-16-2012 | 04:22 PM
Default trim tabs
I am gettin full imco hydrualic steering installed as we speak. to help with the chine walk
Old 04-16-2012 | 05:41 PM
Dave M's Avatar
Veteran: Navy
I never owned bennet style tabs but wonder if they really have that much of an impact. I had 280's on my 24 Superboat and it was like putting the brakes on. Even at neutral they scrubbed some speed. I used them to keep the nose down in the rough but didn't need them when flat.
Dave M is offline
Old 04-16-2012 | 06:52 PM
ok i put 28in on mine they drag i cut them down to 18in your boat will be out of the water the tap are in the air.if you are tracking level. now if you got a prop that give you a lot of bow lift your tabs will be draging. so if you put long taps make them sit high. i only use them when i have a lot of fat guys with me:
bajabob is offline
Old 04-17-2012 | 12:10 AM
Default trim tabs
I don't know what kind of tabs they are. They have dual hydraulic pumps on them. Not sure what they are. I do notice a difference when i use them. When i put them all the way down. I lose about 10 to 15 mph. They do bring the nose down when i use them, and i get out of the hole and my bow comes down quicker when i use them, I have have to look at them when i get the boat back and see if i can find any writting on them.
Old 04-17-2012 | 07:19 AM
DRP
Wasn't someone making duplicates of the 280's to bolt up to the dual ram? If anyone knows where to get them or someone has some that they want to sell, please pm info. Thanks
DRP is offline
