Air bag Explanation
Old 04-18-2012 | 09:24 AM
Default Air bag Explanation
Understand what air bags are and how to install but what ones to get. They have 2000lbs and 5000lb for the most part, is that all they can carry, or is that the added support they provide. Thinking about just doing manual pump ones. Have a F150 and tow about 9500lbs.
soldier4402 is offline
Old 04-18-2012 | 10:10 AM
You will have nowhere near 5000lbs of pressure on your tail with an F150 and its tow rating, even though you are towing 9500lbs. Your tongue weight of your trailer is what will compress the airbag or anything in the bed of your truck. The airbag should add to the spring though.
sleev-les is offline
Old 04-18-2012 | 10:54 AM
Plum_Crazy's Avatar
I run the Air Lift Loadlifter 5000 bags on my 2500HD Silverado. They make a nice product.
Plum_Crazy is offline
Old 04-18-2012 | 11:42 AM
thanks. So you guys think they are needed or not, some people swearing by then, but if they never will be used.
Old 04-18-2012 | 12:09 PM
I don't run them on my Ram 1500 and its fine.... I didn't run them on my Chevy 1500 when I had it either. Both pulled my 25' AT pretty well.
Old 04-18-2012 | 12:12 PM
Even 5 to 10 lbs in those bags help allot with support and stability .
575cat is offline
Old 04-18-2012 | 12:16 PM
Charter Member#1545
I run the Air Lift on my 12 SD. Makes a big difference. Here is a picture without the bags inflated. Quite a difference.
BTW, go with the remote controller. No lines to run to the cab. It works great.
Sam
Neverfastenuf is offline
Old 04-18-2012 | 12:27 PM
i am mechanically inclined they look to install in an hour or less, is this true
Old 04-18-2012 | 01:41 PM
Charter Member#1545
My technicians can install just the bags in an hour or so, depending on vehicle. The pump and wiring another hour or two, again depending on vehicle.
Sam
Old 04-18-2012 | 01:46 PM
ok thanks for the info, have to think about it, seems as if im getting conflicting ideas on to do it or not, and if they arent ever really going to be used as in i never put anything heavy enough in the truck for them be compressed I dont know.
