Amsoil Z-Rod 20W50
Anybody tried Amsoil Z-Rod 20W50? Seems like a great no brainier for marine. Has added ZDDP as well as rust and corrosion inhibitors for long-term storage. I talked to Amsoil on the phone and this is what they recommended for marine use.
In heavily modified engines (e.g. forced induction, nitrous) the maximum drain interval should not exceed 3,000 miles or one year, whichever comes first.
The initial reason I was considering it was the 3,4,5 week periods between use in this fine Florida salt air.
I can see temp difference in Dominator 15-50 myself. Before last tear-down, the 20/50 was used and it was nice too but did not stay as cool as long.
You can do long, hard runs on the Dominator (at lease I can). Should have Rage try that oil.
My other thought was to run 1 quart of Dominator 60 weight with 7 quarts of 15W50.
You & Rage will understand especially... I dont see as good of oil pressure with the 496 at idle with 15 anything. I like 20W50 but Dominator 20W50 doesnt exist. So, in my search I found this.
Even 18 or so is fine at idle. cold it's 65. over 200 degrees it's around 20.
I use 10 as safety and it does not hurt anything.
It's all opinion on oil etc. I wouldn't worry too much. I don't know anything about the Zrod oil you asked about so see what you think.
8, 9, 10 - I cant remember with the new oil cooler. I go till it is at or slightly over the full mark after its hot and shut down.
Dont you have a low oil pressure beep go off at 18psi? I honestly have wondered how much is line pressure at the gauge and true oil pressure.
