HELP! EMI Installation
Old 04-19-2012 | 07:44 PM
scottw's Avatar
Default HELP! EMI Installation
Anyone ever run into this problem? EMI Manifold on port side of Gen IV 454 Mag. Manifold will not clear pressure line coming out of back of power steering pump. What did you do to resolve this issue?
scottw is offline
Old 04-19-2012 | 08:27 PM
Relocate ps pump with their bracket.
looseconnection is offline
Old 04-19-2012 | 08:29 PM
sh!t i bought emi thunders for my 502 efi's. im pulling the boat out of storage this weekend i better take a look and see if im gonna have the same problem
88bullet is offline
Old 04-19-2012 | 08:32 PM
banjo bolt perhaps
tunertech is offline
Old 04-19-2012 | 08:41 PM
scottw's Avatar
Tell me there has to be a better way then that. Going to a local hydraulic hose making place tomorrow to see what they can do about making a new hose that will work.
scottw is offline
Old 04-19-2012 | 08:42 PM
scottw's Avatar
Originally Posted by tunertech
banjo bolt perhaps
Never heard that before. What is that?
scottw is offline
Old 04-19-2012 | 09:06 PM
https://www.google.com/search?rlz=1C...4d42831c954613
google banjo bolt. I saw a setup once the basically replaced the pressure line from the pump. I will dig into it a little more.
Many brake line components use banjo bolts.
Old 04-19-2012 | 10:15 PM
I screwed around with hydraulic shops trying to fit a hose on a ps pump with no luck. But not many around my area. Good luck.
Old 04-19-2012 | 10:56 PM
Default fixx
yep have done a few..you need to put a sharper bend in the 90* fitting,,almost 120* and it will fit..i ran the hose along the intake and valve cover and used a slightly shorter belt.
run the hose along side the valve cover and once you follow the curve on the front of the valve cover you will w\see wht i mean,the 90/120* part will be facing the towards the intake..leave the fitting loose and tighten the belt first then position the fitting and tighten it..
FIXX is offline
Old 04-20-2012 | 02:25 AM
Imco exhaust is almost the same and I had to use their bracket. It looks like you might be able to make it clear on your EMI's by doing as mrfixall said.
Griff is offline
