Hp standard dampner plate rating?
I have got an issue here, I am questioning the Hp rating for stock dampner plates. It may be an easy one as I suspect that if I am at the Hp level that cast flywheels won't suffice then I ought to go ahead and replace these two.
However if they can handle 700 or 750 I may just run them. I see that the next step up from stock is 1000 trq ratings. This is where it makes me wonder if the stock might work.
Thanks in advance.
Thanks in advance.
