502 bbc hp with aluminum heads and cam work
just looking for some general information how much horsepower can a 502 bbc make with just changing the heads (aluminum heads) and doing work to the cam with a holley efi system but still keep reliability and stock bottom end.
You can easily make 600-630hp and 600+ ft lbs. If you want one stop shopping Marine Kinetics can set you up with the complete package.
On the build platform you are talking about (502 BBC - NA), the real power and cost is in the heads. The cam is straight forward providing you are working with a true marine professional - Bob Madera. Don't discount the intake as there is power there to be had or loss too.
The most power development is what your choice is for heads and at a minimum there are CNC ported, or you go for the maximum potential of hand porting. That is another entire subject matter. Don't let flow numbers confuse what porting methods or design perform the best.
Most everything else you upgrade will produce a more reliable motor package. Example: If your block contains a stock GM forged crank, it is externally balanced. Internally balancing the crank will not net you a given power increase, however it will add reliability.
Speaking of a 502 C.I. natural aspirated marine motor, what would be very very interesting is having a "Marine Masters Engine Build Contest". Using some baseline criteria:
502 C.I. Naturally Aspirated Single 4150 or 4500 carb or TBI or port fuel injection (no direct injection allowed)
92 octane consumer grade pump fuel (no additives allowed)
Specific designed exhaust system to be used for every motor entered into the contest
RPM limited
All other rules and regulations follow the Engine Masters program. Now THAT would be interesting.
It would be "Put up or
RPM limited
RPM limited
RPM limited
I'd like to present a more wide view way of looking at any good power and torque production from any performance engine including marine performance engines.
Good base short block with good ring to bore seal + weak heads (poor valve job or flows)+ good camshaft+ good induction system+good exhaust = poor horsepower and torque production per cubic inch.
Good base short block with good ring to bore seal +good heads + poor camshaft choice+ good induction system+good exhaust =poor horsepower and torque production per cubic inch.
Good Base short block with good ring to bore seal+good heads+good camshaft choice+ good induction system +poor or weak exhaust = poor horepower and torque production per cubic inch.
Good base short block with poor ring to bore seal+ good heads + good camshaft choice+ poor induction system+good exhaust = poor horsepower and torque production per cubic inch.
Poor shortblock with poor ring to bore seal + good heads, good camshaft choice+ good induction system + good exhaust = poor horsepower and torque production per cubic inch.
And Finally:
Good base shortblock with good ring to bore seal+ good heads+ good camshaft choice+ good induction system +good exhaust = GREAT horsepower and torque production per cubic inch!
What does this obviously mean, again gentlemen, engines are air pumps that burn air and fuel mixed properly in the combustion process. If any of these systems are weak . ie. shortblock, heads, camshaft, induction and exhaust, you are going to end up with weak results! Don't ever look to one or just a few of these areas to provide you with a good end result!
You must make sure that you have the operative word "Good" in all these 5 areas to produce an engine that will provide maximum horepower and torque per cubic inch within some basic marine performance engine parameters, ie: camshaft designs and sizes may be limited by possible reversion issues in a wet exhaust, compression ratios will be limited by fuel octane and type burned, exhaust may have varying efficiencies based on physical space and routing restrictions and the overall quality of these 5 systems will vary also by the available budget for the total build.
When you are planning, specing, building or rebuilding a marine performance engine always try to look at all 5 of these systems and combine the best combination of these 5 to give you the best overall result in power and torque.
Don't get hung up on one or two and not put the same effort into the other three or four as your end result good or poor will be directly proportional to the overall effectiveness of all 5 systems!
Good Block
Good Heads
Good Camshaft
Good Induction System
Good Exhaust
JMO, but one I feel will always produce the best results!
Best Regards,
Ray @ Raylar
And Finally:
Good Block
Good Heads
Good Camshaft
Good Exhaust
Best Regards,
Ray @ Raylar
