Tons of top notch BBC parts! Make offers!
Most of these parts have less than 10 hours. email at [email protected] if inbox fills. you pay shipping.
Dart Big M Block - $3500 (whole short block)
9.8" Deck Height
SRP Pistons
FlatTop - Dish - Dome
EAGLE 4340 FORGED STEEL Crank
4.25" Stroke
EAGLE 4340 H BEAM 6.385" Rods
KING ALECULAR PRO RACE Bearings
MAHLE Rings
block needs a little hone work but excellent shape
AFR BBC 305 cc as cast, Race ready, w/cnc chambers,
complete w/parts, Inconel valves, flat mill w/ head studs - $2300
Scorpion Marine Endurance BBC Rocker Arm 1.7RR/7/16 - $250
pushrods for this setup (Trend Perf.) - $150
Hydraulic roller lifters - $450
Bob Madura Marine Kinetics Roller Rocker Cam flat nose cam- $350
(Intake & Exhaust
LOBE SEPERATION = 112.1 CAM DEG
valve overlap= 23.7 CRANK DEG
INTAKE
valve open = 15.1 BTDC
• CENTERLINE---> 108 ATDC
valve close= 51.5 ABDC
DURATION-----> 246.5 CRANK DEQ
lobe lifts .37543 IN.
VALVE LIFT---> .63824 IN.
lobe area = 31.38 IN * DEG
EXHAUST
valve open = 81.4 BBDC
* CENTERLINE---> 116 BTDC
valve close= 8.7 ATDC
DURATION----> 250 CRANK DEG
lobe 1ift= .36445 IN.
VALVE LIFT---> .61956 IN.
lobe area= 31.04 IN * DEG)
Dominator 1050 carb rebuilt by Pro-Systems for this setup - $500
Brodix race intake - $175
Cometic head gaskets - $125
Melling oil pump - $75
Professional Products PowerForce Plus Harmonic Damper - $200
Taylor ThunderVolt 8.2mm Spark Plug Wire Set,8.2mm,black - $50
Moroso braided stainless dipstick - $30
Hi-Perf Power Steering & Engine Oil Cooler - $325
10" x 3" Dominator Flame Arrestor, Polished Stainless Steel - $125
BBC 10qt. Performance Oil Pan-Gen. 4 - $325
Xtreme High Flow 3/4" NPT Side Inlet Oil Block Adapter - $85
Polished aluminum valve covers with breathers - $175
BBC crossover kit with bypass, stainless - $250
Daytona Sensors CD-1 ignition w/ coil and harness (1 ignition system) - $450
Lightning headers with fully dry tails (grey) - $2000
Make offers! All is going on craigslist/ebay shortly.
9.8" Deck Height
SRP Pistons
4.25" Stroke
MAHLE Rings
(Intake & Exhaust
INTAKE
EXHAUST
