How far should the center of the prop shaft be below the bottom on a single engine? >
Old 04-24-2012 | 09:59 AM
Default How far should the center of the prop shaft be below the bottom on a single engine?
I feel as if my boat needs a -2 or -3" lower unit. I am currently running a std length imco lower, with a 5 blade P5X. What is the best way to tell if the shortie is the way to go?
onestrghtridaa is offline
Old 04-25-2012 | 01:34 AM
Really depends on the bow lifting characteristics of the boat. on my boat, a single step, pad bottom I am at 3.25" below the hull, and would like to try another inch up. Some other boats need the bow lift that a deeper prop provides.
What makes you think you need to go shorter? how deep is your prop shaft currently?
Philm is offline
Old 04-25-2012 | 12:09 PM
3-5" below the bottom is the norm.
Griff is offline
