Pics of a Wieght Distribution set up on boat trailer >
Old 04-24-2012 | 07:45 PM
Default Pics of a Wieght Distribution set up on boat trailer
Does anyone have a picture of this. Do they make em for our boat trailers or are they for trailers with the A frame front at the ball.
Allicat38 is offline
Old 04-24-2012 | 08:20 PM
Bigger question is what type of brake actuator do you have? Many WD units effect the proper function of a surge brake system. If you have an EOH system then you have a lot more options. Here is a link to one system that does work with a surge system.
http://www.etrailer.com/Weight-Distr...e/RP66153.html
For I-beam type trailer like our boat trailers you will need something like this...
http://www.etrailer.com/Accessories-...e/RP58393.html
Hope this helps!
502ss is offline
Old 04-25-2012 | 09:50 AM
Lets maybe back up......
What is to be towed and why is WD being considered?
ChargeIt is offline
Old 04-25-2012 | 02:14 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I posted pics of my old setup in the past. Do a search. It MUST be set up well. It can be done with a surge brakes, but I highly recommend only doing it with an EoH brake setup.
You will require a Pole Tongue Adapter as referenced above.
Sydwayz is offline
Old 04-25-2012 | 03:30 PM
electric brakes on mine. I dont need it but im reading about others who have them. Wondering how that works on a trailer with a straight tounge.
Old 04-25-2012 | 03:33 PM
I see in the links now. There is a bracket that bolts to the tounge. Still anyone got pics would like to see them.
Old 04-25-2012 | 04:07 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Found via search function.
http://www.offshoreonly.com/forums/g...tongue+adapter
Sydwayz is offline
Old 04-25-2012 | 07:56 PM
thanks sydwayz
