Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Gelo coat safe paint remover >
Old 04-26-2012 | 01:33 PM
onesickpantera's Avatar
Default Gelo coat safe paint remover
Did a google search and found a few(Peel-Away and Ready-Strip came up the most) but none of them had very good reviews.
Is there anything out there that will actually remove paint without hurting the gel coat?
onesickpantera is offline
Old 04-26-2012 | 01:49 PM
Your graphics? Or overspray?
POWERPLAY J is offline
Old 04-26-2012 | 02:06 PM
Graphics.
Old 04-26-2012 | 02:11 PM
It is possible. I think it has been discussed here as to what works best. I don't have stones big enough to try on mine lol. Keep in mind there will most likely be a discoloration and an outline that may or may not wetsand and rub out.
Old 04-26-2012 | 02:50 PM
Yeah I figured there would be an outline from fading. I was going to do a small test spot and see if the outline could be wet sanded out.
Or just do yours first and let me know what works best!
Old 04-26-2012 | 03:45 PM
Haha no thanks. I'll get around to painting it one day. PM Overlimits on here. Friend of mine and might know what ya need.
Old 04-26-2012 | 09:54 PM
I tried it on mine. It does work, but it will soften the top layer of gel and cause it to swell up. Don't do any sanding on it for a while after until all the solvents escape and it shrinks back down. I only did one stripe before I quit and just sanded the rest off. In my experience it sands off faster and you dont have to worry about stuff coming back to bite you later.
C.I.M. is offline
Old 04-26-2012 | 10:13 PM
Default fixx
+1 sanding is the safest route..buy yourself a hutchins palm sander with hookit sand paper,start with 600 then work your way up to 2000,then buff with ultra buff and go boating,,thats if you want to stick with jusr the gel.
FIXX is offline
Old 04-27-2012 | 07:06 AM
they do make a air craft striper that is safe for gel coat. People that restore old vette's use it.You can always da sand it and buff it. How much paint is on it ?
excalibur82 is offline
Old 04-27-2012 | 10:00 AM
Thinking of removing the stripe on the boat(see avatar) so not a lot. Looks like sanding is the safest way. Although orbital sanders scare me. LOL
