Cutting Edge Props on 29 Outlaw >
Old 04-30-2012 | 08:58 AM
Default Cutting Edge Props on 29 Outlaw
Finally had a chance to run the new props for a couple passes yesterday (Sunday) before the weather (wind) got out of control down here again. Props were Bravo 1 28's...Temps in the low 80's, typical Houston humidity and overcast out. Mid-range acceleration was amazing and top end was 78.9-79 at 5100 RPM. Very happy with the overall set up and thank you to Greg with Cutting Edge Propellers...great guy to deal with.
HOSSMAN is offline
Old 04-30-2012 | 09:31 AM
How about cruising speed at 3500 or so?
jmeng is offline
Old 04-30-2012 | 01:31 PM
46 @ 3500. What was the most amazing was the handling and the mid-range acceleration. Even my wife who knows squat other then how to look pretty on the boat said "wow". For stock black motors from say 3-3500 and showering down on the throttles it would put you back in the bolster.
HOSSMAN is offline
Old 04-30-2012 | 04:20 PM
What kind of numbers were you seeing before the prop tuning?
ozarkdevil is offline
Old 04-30-2012 | 06:14 PM
In my testing in cool 60-70* low humidity weather 4900/78, in the heat was 47-4800 and 75-76. Props have been re-done a few times.
I only made 3 passes before the weather got too bad so I still need to fine tune but overall very happy with the overall results thus far.
HOSSMAN is offline
