formula 336 rear seat and hatch help
time to recover the rear seat on a 95 336 .the wood part everything get staped to is all rotted .does anyone have a template for this i called formula and all the prints were cnc cut and long gone .also the wood on the hatch is gone as well if anyone can help or has ideas let me know
You doing this yourself and sewing everything, or just want the patterns so you can take them to a shop?
I redid my swim platform and some of the rear bench cushions on my 86 - 272. Let me say I did this the easy way and suspect you do NOT want to do what I did. But I will throw it out there anyways...
Page 7 of my build thread. New plywood and vinyl for the whole hatch, re-used the foam and fiberglass panel and aluminum trim. Also did two of the cushions for the back of the seat. (Mine are all individual cushions). I am very happy with how they turned out, but I am cheap! LOL!
Good luck, Brian
http://www.offshoreonly.com/forums/f...-272-ls-7.html
Good luck, Brian
Wood is rotted nothing to go buy. As far as upholstery ill have my shop do it. I just have no frame for the rear seat
Smokin Gun,
I might be able to help you out. Of course it would be easier if you were closer. Redid my bench seat and made patterns and jig for the arm rest. I see the 336 is one piece where mine is in 3 pieces, but the arm rest are the more difficulty to build. For yours I would make both arm rest the same as mine and then build the center piece. Here is a few pics.
