Need Heavy Duty Winch. Options??? >
Old 05-03-2012 | 05:42 PM
ballon78's Avatar
Default Need Heavy Duty Winch. Options???
redoing my trailer, just ordered a manning bow stop, and want to get a new winch, something real strong, not flimsy, with 3" drum so i can do a 3 inch strap, also where do i get the straps..
96 HUSTLER 32, Vacuumed bagged layup, composite transom Blueprinted 502EFI's Mayfair, Dry-exhaust
ballon78 is offline
Old 05-03-2012 | 07:55 PM
I just purchased a Powerwinch RC 30 Wireless Remote Trailer Winch. Rated to pull 11,500 boat. 4000 pound vertical lift. Comes with pulley that ups vertical pull to 7500 pounds. Has built in light and key fob wireless remote. 40' cable. Comes with wiring. I paid $450.00. I'm using it on my bunk trailer with a 29' Fountain with twins. Probably a bit lighter than your boat. I will try it without the pulley first and use the pulley only if needed. I pretty much had to float the boat on the trailer with the hand wench. I'm hopeful that I will not have to put the wheels in the water with the power wench. The RC 30 was the most powerful I found online. Good luck with your search.
Wes Burmark is offline
Old 05-04-2012 | 06:11 AM
ballon78's Avatar
i dont want to to go with an electric one, mine floats on fine and i dont like draging the boat on the bunks, it then to sctrach the bottom, mine weighs abot 7500. looks like fulton makes a 3700 pound one, its not that i need the weight puling power just want a quality winch not made from recycled tin can from china!!
ballon78 is offline
Old 05-04-2012 | 06:45 AM
From: Northern, KY (Cincinnati) Lake St Clair, MI Norris Lake, TN
I run a strap like this...
http://www.trailerdepotofsarasota.co...00-lbs-p-15183
Baja_342 is offline
Old 05-04-2012 | 11:09 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
Fulton 2 speed winch.
US1 Fountain is offline
Old 05-05-2012 | 05:39 PM
I just installed a Fulton F2 3200#.
2 speed plus the handle has 4 length positions for leverage.
nicely machined and very smooth. Installed a separate HD 2" strap rated 10k. ws20hd600
Only been on two weeks but a huge step up from the standard stamped winches
ChargeIt is offline
