Trailer Runway Lights
Any of you guys seen them?
http://caravelleboat.com/forum/viewt...er=asc&start=0
activated by a water switch so as you dunk the trailer they kick on, light up the trailer from underwater so you can see where it is at night?
pretty trick, anyone done it?
some use a bildge switch but some use a switch that uses water to make the connection so there is no moving parts. the power comes fromt he running lights. so the switch only has power when hooked to a truck thats On, and then it needs to be under water to activate. SOME will wire in a separat hand switch so they can turn them on once out of the water.
Well the thread shows them using rollsof water proof strips.
http://www.buy.com/prod/lighting-eve...223045399.html
then attaching to a water switch... I am thinking for under 150 (104 is 4 LED stips,) makein 2 32 foot long underwater lights and a switch and wireing and its done...
